Weather is not showing right
hi
can you explain from where it recive his weather information.
I am is israel and it is not showing the right c temp’
tnx
elad
Weather widget can use display location or you can specify the longitude/latitude in the widget itself.
When it is set to use display location it will use the long/lat set for the specific display, if it’s not set there then it will use the default long/lat set in the CMS Settings - all of which you can of course adjust.
