Xibo v2 R202
When I add an external App/Script in the XiboWatchdog.exe.config in “Xibo Player\watchdog\x86” as value under the ExtWatchdogPath Tag, it gets called everytime the XiboWatchdog checks if Xibo is running.
But that doesn’t work when I install our White Label version. If I replace the Watchdog from the White Label version with the one from the standard Xibo version it works again (except the Task Icon isn’t from White Label anymore, obviously).
I think there is a fault while building the White Label version.
