Video Codec - Fault 2001
Hi, I tried uploading a MP4 video H264 and 30fps, but it did not work. Always same error on different players. Just do not know what to do. Any help appreciated. thanks Mark
Take a look at the Re-encoding Video section on this page. Use Handbrake’s General > Fast 1080p30 preset.
The error suggests that its the audio track that’s problematic.
Please be aware that you may need to restart the device to get it to start working.
Looks like you are using Android.
Test this with the Android application ExoPlayer. If it works, than it should works. Also mp4a is not a standard codec.
