(v 2.2.1) The owner is not changed when copying a playlist. Also, tags are not copied
Hello.
I am a user of cms 2.2.1
I found the following and I will write it down.
(event)
・As the title suggests.
Items of owners other than yourself that you copy through the [view] [edit] permission are created but not displayed on the screen.
Thank you for reporting this - you’re absolutely right. I’ve created a bug report.
Thank you for your response.
I am waiting for the correction.
Thank you for your continuous support.
