I’ve created a template to use with all our layouts. The template has a running line at the bottom.
Our users prefer to use different layout for each picture. The layouts run for 30 seconds each. That causes the running line at the bottom of the template to stop each time and run from the beginning. The 30 seconds of the layout are not enough for the line.
Could someone advice me a workaround for that? We do want to have a template with the running line.
I could create one layout with several pictures, but they should be stopped at different times.
