Using not necessary
in .net client - IeWebMedia the following rows can be delete:
using Xilium.CefGlue;
using Xilium.CefGlue.WindowsForms;
what is XmdsResetTimeout (it seems like not used) ?
@dan you probably need to look at this…
It’s not used any more, but I’ve kept it around in case anyone is using it in their own custom code. It was the time out before backing off to XMDS. It has been replaced with logic that extends the collection interval with each failed connection.
Your are correct, they don’t need to be in IEWebMedia - if you’d like to submit a pull request with them removed, that would be great.
