Using a campaign as standard?
Hello.
I would use a campaign by default, and not a layout, you can?
I assume you mean as a default layout?
Well, in this case, no, only layout can be set as a default layout :smile:
Exactly, Default Layout.
Maybe that can be added on next update?
It will be very good.
Default layout is designed to serve as a ‘fall back’ ie when there are problems with scheduled content it can be displayed fine, so that’s why it’s a only single layout (which we recommend to be something simple not often changed).
Feel free to create a feature request for it in appropriate section.
I understand the reason for the Standard Layout.
But as scheduled layouts are not running when the device is no internet, the only alternative is to use the default layout.
But with him the aforementioned problems occur.
I will request the correct, thank location.
