After following the Upgrade and switch to Xibo for Docker install guide including importing the exported database none of the ‘users’ can login.
The original server is running Xibo 1.7.5
If i connect to the cms database using mysql and try to rest the password for the users, e.g. admin, i get Error 1146 (42502): Table ‘cms.admin’ doesn’t exist.
Using PHPmyadmin to look at the database and compare with the database on the original server i can see that several tables are missing (everything after ‘oauth_client_scopes’ missing) and therefore the User table is missing.
No matter how many time i export/import the datebase i get the same result. I am using PHP myadmin to export the database as on the original server when i try to run Mysql in powershell it comes up as unrecognized command.
Also after i run ‘docker-compose up -d’ the xibo-docker-238_cms-db_1 container keeps restarting for a while before it will stay ‘running’.
The only login that works at all is ‘cms’ using the database password, however this opens the web interface with only the Dashboard and a message saying ‘error Sorry the form has expire. Please Refresh’. Refreshing doesn’t change anything.
Can someone help me get this sorted out? Thanks
