Use Layout as a material in region
HI,
In 1.8.0, is it possible that the contents of a region can be re-used across multiple layouts? I think it’s a great feature but I can not find it in 1.8.0 alhpa
Yes and No… the ground works are there for it, but there isn’t any user interface yet. Partly because we haven’t fully decided how the user interface should look and partly because we have been consumed with adding other things.
It will definitely be in the beta version, when we release that.
