Upgrading Xibo for Android
The latest APK version of Xibo for Android can be downloaded from the Download Centre.
{tip} Please note: Remote upgrades are available from v3 R301 and later for Philips Signage SoC Monitors that are running Android 8 or later.
For v2 Players, Philips Signage SoC Monitors can be remotely upgraded from v2 R217. {/tip}
White Label customers
The latest APK can be built and downloaded from the Customer Portal. All White Label builds are initially set to “Latest” and are rebuilt automatically on the day of release, ready for download.
Please note: If you have set a specific version you will need to manually choose the new release and then run the build.
Download, Upload and Install
Download the new APK version and upload it to your CMS. Please follow the appropriate instructions from the left hand menu for the Xibo CMS version you are using.
CMS v2 / v3 and later
CMS 1.8.12 - 1.8.13
CMS 1.8.11 and earlier
Please note: From 1.8.12 if you have different models of Player that need different Player Versions on the same CMS you will need to create a Display Profile for each Player type. This can be easily done by using the Display Profile Copy button on the Display Settings page.
