When upgrading a working 1.7.9 installation to 1.8.2 docker with external sql server, I get the following error:
Step 8: 1.8.0-alpha Convert Page Permissions SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘groupId’ in ‘field list’
Step 8 is the first step on the upgrade web page.
I also tested running with mysql in the docker, same problem.
With sql in docker, i get this messages when starting docker:
cms-web_1 | MySQL started
cms-web_1 | Attempting to import database
cms-web_1 | Importing Database
cms-web_1 | Configuring Database Settings
cms-web_1 | Setting up Maintenance
cms-web_1 | DBVersion
cms-web_1 | 94
cms-web_1 | Configuring Backups
cms-web_1 | Running maintenance
cms-web_1 | Unable to run upgrade step. Aborting Maintenance Task.Starting cron
