using config file ./phinx.php
using config parser php
using migration paths
/home/xibo/public_html/db/migrations
warning no environment specified, defaulting to: production
using adapter mysql
using database xibo-cms
All Done. Took 0.1163s
I would like a help to know what is missing to do for the command to update my version.
using config file .homexibopublic_htmlphinx.php
using adapter mysql
All Done. Took 0.4980s
My question is this, do I need to download the installation package for Linux and unzip somewhere and repeat the command, or does this command download the update and install it automatically?
All that command does it run the migrations that are part of the Xibo CMS install. It’s not like Docker where it downloads the files and the environment for you.
You’d need to download the 2.3.0 CMS and replace your existing CMS installation with the new version, persisting your library and the settings.php/settings-custom.php files before you try and run the migrations.
