i have not understand something, if i just save settings.php and remove all. How i will keep all my user’s images in Xibo ?
I don’t know in witch folder they are.
Thank you very much for your help.
Have a good day.
So,
i give you my parameters and a screenshot of the website’s folder.
So, before update,
i just need to save the files i show in the red square in filezilla, and settings.php, then, i remove al the websitel, upload 1.8.11 and upload the library files in the new folder ?
Your configuration isn’t valid. The library path must be fully qualified.
You’ll need to find out from your hosting provider what the correct path is to use.
In any case, you’ll need to keep settings.php and the xibolib folder when you upgrade, plus anything else you’ve customised (any custom themes, middleware etc).
It looks like you’re using some kind of shared hosting. Please ensure XTR is being run properly otherwise you’ll have all kinds of issues with the CMS.
