As I am in the progress of testing my upgrade process I run in to the problem that the upgrade process stops at “Step 65 - Convert existing DataSets” telling me my data is not compatible:
“Existing data is incompatible with your new configuration”
Are there any restrictions on the datasets to be correctly converted? I searched for it,but couldn’t find it.
That’s a definitely valid thing to do, unfortunately I’m not sure what exactly may cause the dataSet error on upgrade, that’s why I’ve mentioned Dan, he should reply once he will have a moment.
What do you have in your dataSets in 1.7.4? I’m not sure why would it be incompatible, but perhaps it would help to know what do you have in them.
Edit. I believe there was a problem (on upgrade) in 1.8.1 when dataSets had list content, but I believe that was fixed in 1.8.2 to which you’re upgrading now.
I have about 50 datasets, all with about max 10 rows.
I allready encountered a problem that some did not have a description, or the description of the dataset was the same as another. I renamed the descriptions for these datasets by hand in the database to be imported.
The strange thing is, some ( about 8 ) datasets are imported correctly.
All data in the datasets is just plain text and numbers. (All strings) No list are used as far as I can see.
The old installation was a manual 1.7.4 installation. The upgrade is to 1.8.2. in Docker. What I wanted to try myself was upgrading to 1.7.9 manual and then to 1.82 in Docker.
If I can send you something, no problem, please let me know what you need. (And if it is needed that the upgrade process is allready ran or not.)
Our recommendation is to go to 1.7.9 before trying to upgrade to 1.8, as that’s the best tested route. So I’d try that locally first, and failing that, we can have a look at your data here.
