Upgrade 1.7.9 -> 1.8.1 fails at step 103
I am running a non-docker version trying to upgrade from 1.7.9 to 1.8.1. Initially upgrade process was failing at step 90 which I found a workaround here, but after running the workaround sql query and restarting the upgrade process, it failed at step 103 with the following error:
2404,3626425,"2017-05-04 09:52:52",WEB,/update/step/103,POST,"Unable to run upgrade stepId 103. Message = SQLSTATE[42S21]: Column already exists: 1060 Duplicate column name 'released'",,ERROR
2405,3626425,"2017-05-04 09:52:52",WEB,/update/step/103,POST,"#0 /var/www/xibo-cms-1.8.1/lib/Entity/Upgrade.php(79): PDO->exec('ALTER TABLE `me...')
#1 /var/www/xibo-cms-1.8.1/lib/Controller/Upgrade.php(128): Xibo\Entity\Upgrade->doStep()
#2 [internal function]: Xibo\Controller\Upgrade->doStep('103')
#3 /var/www/xibo-cms-1.8.1/vendor/akrabat/rka-slim-controller/RKA/Slim.php(79): call_user_func_array(Array, Array)
#4 [internal function]: RKA\Slim->RKA\{closure}('103')
#5 /var/www/xibo-cms-1.8.1/vendor/slim/slim/Slim/Route.php(468): call_user_func_array(Object(Closure), Array)
#6 /var/www/xibo-cms-1.8.1/vendor/slim/slim/Slim/Slim.php(1357): Slim\Route->dispatch()
#7 /var/www/xibo-cms-1.8.1/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#8 /var/www/xibo-cms-1.8.1/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#9 /var/www/xibo-cms-1.8.1/lib/Middleware/Actions.php(141): Slim\Middleware\MethodOverride->call()
#10 /var/www/xibo-cms-1.8.1/lib/Middleware/Theme.php(35): Xibo\Middleware\Actions->call()
#11 /var/www/xibo-cms-1.8.1/lib/Middleware/WebAuthentication.php(132): Xibo\Middleware\Theme->call()
#12 /var/www/xibo-cms-1.8.1/lib/Middleware/CsrfGuard.php(62): Xibo\Middleware\WebAuthentication->call()
#13 /var/www/xibo-cms-1.8.1/lib/Middleware/State.php(109): Xibo\Middleware\CsrfGuard->call()
#14 /var/www/xibo-cms-1.8.1/lib/Middleware/Storage.php(47): Xibo\Middleware\State->call()
#15 /var/www/xibo-cms-1.8.1/lib/Middleware/Xmr.php(36): Xibo\Middleware\Storage->call()
#16 /var/www/xibo-cms-1.8.1/vendor/slim/slim/Slim/Slim.php(1302): Xibo\Middleware\Xmr->call()
#17 /var/www/xibo-cms-1.8.1/web/index.php(124): Slim\Slim->run()
#18 {main}",,ERROR
2406,3626425,"2017-05-04 09:52:52",WEB,/update/step/103,POST,"Unable to rollback. E = SQLSTATE[42S21]: Column already exists: 1060 Duplicate column name 'released'",,ERROR
2407,2aedb99,"2017-05-04 09:52:57",XMDS,GetResource,POST,"SQLSTATE[42S22]: Column not found: 1054 Unknown column 'display.auditingUntil' in 'field list'",,ERROR
2408,d99616c,"2017-05-04 09:53:57",XMDS,GetResource,POST,"SQLSTATE[42S22]: Column not found: 1054 Unknown column 'display.auditingUntil' in 'field list'",,ERROR
2409,1b73b64,"2017-05-04 09:54:13",WEB,/update/step/103,DELETE,"Upgrade step skipped. id = 103",,CRITICAL
If I proceed with skipping this step upgrade completes successfully and cms appears to be working - I can see media/layouts/etc. Should I be concerned about this error? If so - I rather go back to 1.7.9 and wait for resolution.
If you don’t have any more of those in the logs (perhaps truncate the logs and then watch them for a bit), then you should be OK to leave it.
