You will probably have an issue to make XMR working for you, but other than that, everything should be fine, may I assume that the upgrade was successful or do you still have some issues?
A test upgrade seemed to be working, although when I did the same with the primary setup, when I put back the settings.php and got to the CMS, it just logs me in and shows me the new CMS without updating database tables. In the “version” table I see version 1.8.1 but many functions were clearly not working and I don’t see my layouts.
I’m restoring a backup today and trying again for the sake of perfection
And by “shared hosting environment” i mean it’s shared with other websites of our own. I used an alias to set this up and we have access to the server itself.
And a new fresh install doesn’t seem to be working either, I suppose because we use nginx and Apache. Seems like I have to put up a new VM just for Xibo
If 1.8.1 is in the version table then the upgrade definitely ran. At a guess the issues you’re seeing are browser cache related. You should clear your browser cache and you may well then have a working system.
