I try to Update 1.7.8 → 1.8.1
The Update process stops at Point 43 Upgrade Layouts (Takes infinitely long)
the Log file entries
Does anyone have a solution for me?
Sorry, i’m going to have to ask you to add some additional logging if possible
Can you edit lib/Upgrade/LayoutStructureStep.php
on Line#161, add a new line with this content:
$this->log->error($e->getTraceAsString());
And then rerun the upgrade? I hope this will give us more information.
The log message would imply that it is erroring when logging an audit message when saving one of the regions in one of the layouts it is trying to upgrade.
I don’t really see why.
Can you change
to
$this->log->error($e->getMessage() . ' - ' . $e->getTraceAsString());
better?
Sorry I just found that I did not use the version 1.7.7 as in the heading 1.7.8
I hope that makes no difference
Are you starting from a working 1.7.7 each time? It seems to me that part of the upgrade has already run (i.e. the table already exists because its been created by a previous upgrade attempt).
You can skip that step and see how far you get - but it might be sensible to go back to 1.7.7, delete the layouts you don’t need, and then upgrade from fresh.
