I’ve recently installed xibo 2.02 on a Win 2019 / IIS box.
After following the step by step guide I got the CMS side working OK.
I’ve now come to add a Win client (on an old test PC) but have encountered an error when configuring the Player Options.
I get the following: ‘There has been an unknown error with XMDS, it has been logged’
I can open the Admin ok, and if I deliberately enter an incorrect key i get a key doesnt match error - so I know there is nothing wrong with the address or conn with the server.
Can anyone point me in the direction of where I should look to troubleshoot this error?
Please go to the log section of the CMS, then amend the duration so you can see that particular error more in details and get back to use if you need to then.
If nothing is logged then first check the filter in the log page is set far enough in the past. If still nothing is logged, then try to put the CMS into test mode, which you can do from the settings page>troubleshooting>server mode change to Test.
