Unknown error when i try checkout layout
Hello i have installed xibo without docker the version 2.0.3.
Everything find but i can’t checkout layout and edit them i have unknow error.
I search without find other similar problem.
If i look the console of my navigator js say ‘User Option no found’ on layout page.
I want also say you in the modal every click add new fa fa-cog fa-spin on the button checkout.
When i try edit layout i am log in superadmin.
Best Regards
