Unable to register deleted display
I’m unable to reregister a display that was previously deleted. On the display, I get an error “There has been an unknown error with XMDS”
CMS is running Xibo 1.8.12
Display is running windows 1.8.12-133
Thank you for your message. Can you check the Logs in your CMS around the time you were trying to add the Display? If you see any errors please pass them on. If you do not see any errors, I would recommend trying to register the Player again and then check the Logs again.
Many Thanks
The log shows"SQLSTATE[HY000]: General error: 1364 Field ‘overrideConfig’ doesn’t have a default value"
Thank for providing the error. There appears to be an issue with your database, can you try running the below statement to see if it resolves your issue:
ALTER TABLE display MODIFY `overrideConfig` text NULL;
