Unable to create a db
I am unable to create a db on my webserver
Could not connect to MySQL with the administrator details. Please check and try again. Error Message = [SQLSTATE[28000] [1045] Access denied for user ‘root’@‘localhost’ (using password: YES)]
What are you doing to get that message?
Are you trying to install with Docker? Or a custom installation?
The error message is from your MySQL server telling you whatever password you’ve entered isn’t valid. If you’re doing a Docker install however, then “localhost” won’t be trying to connect to what you think it will.
