Twitter Metro Widget Not Fitting Region Properly
Windows
R304.1-304
Hello!
I am trying to make use of Xibo’s Twitter metro widget. However, for some reason, the widget does not fit properly in the region. I know that for other widgets, it was possible to change the HTML/CSS code to manually adjust the size of the widget in the region, however this widget does not seem to have such customization available. Is there any way to adjust the widget size? Or is this something that can be added at a later date?
Thanks!
Alec
