Twitter Metro Playing up?
So twitter metro was working fine then it said ‘Unexpected Error, please contact support’ in the layout designer.
I found the below in the logs but can’t find the problem, any tips??
Cheers
Update:
CMS 1.8.2
Windows 10 Pro x64
Docker installation
Since I see the same id there in your logs, I’d say it is most likely this bug - https://github.com/xibosignage/xibo/issues/1296
It will be fixed in 1.8.3.
Thank you, any scope on a release date yet?
We do not have a set date for 1.8.3 yet - https://github.com/xibosignage/xibo/milestone/25
