Twitter Help Special Characters - Accents
What should I do to fix it? Unfortunately I do not know where to start.
@Peter - can you try to recreate/help?
Hi @laercionit
I tried to recreate this issue but for me it’s working fine with special characters. (in preview and in windows/android players)
Could you please tell us if this issue still persists? If so what CMS/player version are you using?
Could you provide as with an example? maybe I didn’t do exactly what you did.
Thanks,
Peter
Hello Peter,
The error I mentioned was with the 1.7.3 version. Now using version 1.7.4 the problem was apparently solved.
Ok, so that’s why I couldn’t recreate your issue :smile:
Good to hear that now it’s all good, thank you for feedback.
