Hello
When assigning transitions to videos, it does not default to the values configured in Administration> Settings page.
so it shows
Hello
so it shows
If you ticked to use the default then the defaults will indeed be applied. The edit transition forms do not show the defaults that have been applied but can be used for overriding the defaults for specific widgets.
You should be able to see a transitions icon for the widget on the timeline, however I can see that there maybe an issue with the icon visibility so have raised this with our development team to take a look.
