is it possible to specify transitions between layouts in a campaign?
Example:
Campaign1 contains Layout1 and Layout2
There should be:
Fade-In > Layout1 > Fade-Out > Fade-In > Layout2 > repeat…
Most beautiful would be some kind of cross-fading between the Layouts.
We know there is a Widget Transition and a Exit-Region Transition. But it is unclear how to achieve the goal to transition the Layouts in a Campaign (or if this is possible at all at this moment)?
