I have enabled the “Enable touch capabilities on the device?” but the Android app does not respond to touch. Is it because I am on a 14 day trial?
I am using Code version 300 - b67655d. Thank you.
After much checking, when I set the “Interleave Default” to Yes (Edit Display → Advanced tab), then the touch is responding. Is this by design?
Thanks.
