Timeline Issue with Image & Embedded Code
I’m running v1.8.6 on Server 2012 R2 with Windows clients. I’ve setup a region and added two media types to it. The first is an image that has been configured to have a 15 second duration, and the other is some embedded code that streams a video from Vimeo, and this has a 741 second duration.
The order has been set for the image to play first and then the embedded code to kick in. However, it appears that both are running at the same time, as the image displays and the audio from the video kicks in as well when the image loads. When the 15 second duration for the image is finished it switches over to the video (which is now 15 seconds into play).
Am I doing something wrong or is this a bug?
Thanks,
Kenny
That is interesting and obviously it is not intended behaviour.
Could you please export your layout upload it somewhere (Dropbox/google drive or similar service of your choice) and share the download link with me over private message?
I will then run your layout on my local players to confirm the issue.
