Time for layout
Hello
I have a problem of time with the layouts
Indeed I put my layouts with a duration of 30 seconds but each layout changes after 2 minutes or 3 minutes out on the layout is indicated 30 Seconds so I do not see why it does not work .
Version 1.8.9
Hi, maybe the total duration of the medias within the layout is > 30 sec ?
I remove the RSS feed and it works. So it’s a problem of the RSS feed module
Have you set a duration for the RSS feed module in your layouts ? If not, it might take time to read all of the items of the RSS feed.
I put 10 seconds like the rest of the layouts
