Hello, (Sorry my English is not so good, Google Translate )
I am brand new with Xibo, the system runs perfectly via my WebSpace server and a specially purchased Minipc (Miniforum Win10pro), but I don’t get the time control the way I want it to.
1: I want to use a main layout that runs all day
2: A second layout should be shown every 15 minutes
but now I only see the secound layout which should only be displayed every 15 minutes?
So you want a Layout that runs all the time with another Layout to run for x duration every 15 minutes over a specified period of time.
Your Always configuration is ok, with your Repeat configuration first make sure that the Start and End date is just for one day (you can set an end period on the Repeat tab to set the needed time frame). You also need to set Start and end Times here, as this is where you are setting for how long you want your second Layout to show, every 15 minutes.
You can see in my example above I have selected one day and have that set to start at 8am, for a 5 minute duration. So at 8:06 my Always Layout will resume.
Now I want to Repeat this behaviour using the Repeats tab. Set as Per minute and the frequency and then include the date and time you want this behaviour to end:
A really good way to check what you have scheduled will play as intended is to use the Agenda View, you can use the slider to pinpoint a time in the day as to what will be shown on a particular display / display group. So below is the Agenda view at 7.59 when we see only the Always Layout:
thanks for this great description, I have now entered everything so, but the layout (picture which takes 5 minutes) is not shown to me even though it is on the agenda?
