Time and powerpoint
Hi everybody, i have a powerpoint document and it works good on my display, but i would like in my layout to not define time and let the presentation running all the time and restart each time is finish
How can i do that ?
Unfortunately there is no “end detection” in PowerPoint module, as such you do need to specify the duration of the powerpoint widget.
Alternatively you could export your presentation as a video, then use Video widget to show it, in this case you could have it set to 0 (auto length detection) https://xibo.org.uk/manual/en/media_module_powerpoint.html
