Hi tpipjo, please excuse my delayed reply. I have taken a look at the Logs you provided but I can’t see a link between the messages and your issue.
So far I have not been able to replicate your issue using 2.0.4 and 2.1.0 RC. Below is a screenshot of the Ticker appearing as expected on 2.1.0 RC:
Can you capture some troubleshoot logs so I can take see what is happening in your CMS when you are looking at this Layout? To capture the Logs, please follow the below instructions:
- Log into your CMS and choose the
Report Fault
option.
- Follow the steps and click the
Turn on Debugging
button when it appears.
- Continue to follow the steps and choose
Open in a new Window
when the option appears. Do not close the original window when you click this as you will need it later.
- In the new window, got to the
Layouts
option in your CMS and open the Layout in Designer.
- Now Preview the Layout.
- Once you have done the above, close the new Window that opened and return to the original window with the Report Fault steps.
- Continue with the Steps and click the
Collect and Save
option to create a Troubleshoot zip file containing the Logs.
- Continue once more with the steps and
Turn off Debugging
when the option is available.
I would recommend sending the Troubleshoot zip file to me in a Private message, as it could contain sensitive information about your Xibo setup.
