Ticker parameters to load an attached file in RSS
I’m trying to load the attached images in a RSS feed, but i cant find the right command to do so…
This is the feed i want to load; http://ep00.epimg.net/rss/tags/ultimas_noticias.xml
Is there any command like [Title], [Name], etc that can do this??
Thanks in advance.
The feed appears to be invalid as per - W3C Feed Validation Service, for Atom and RSS
That being said, it should get the images with [Link|image]
ie the very standard substitutions that can be added automatically for you if you select for example ‘Image overlaid with the Title’ Ticker template.
Thanks, this helps me to understand why its not working…
