Ticker not working ( no matter made a simple mistake)
I have entered this data, and want it to be used to display exam times, rooms and other info on my signage, but I followed the example and it does not work, and help would be appreciated.
Does not tick over
thank you.
Well if you look at the dates you have there and at the current date, then when you compare it as it is in the example, it will not display anything - if you’d change it to today’s date, then it should work.
I know I relised after posting sorry for wasting you time
No problem, I’ve seen your title, but just wanted to reply in case anyone else was interested why it wouldn’t work.
I’ll close this topic now.
