Ticker not starting from begin of the feed
I made a layout with three tickers, all pulling data from the same feed. One ticker just shows the date, one ticker displays the image inside the feed and one ticker gets the title and date. All are set to start from the beginning of the feed.
One ticker starts at the beginning of the feed. The other two (the image ticker and the date ticker) are showing data from the end to the beginning, even though they are set to start from the beginning. If I set it to start at the end of the feed, it also starts at the end of the feed. I tried replicating the layout and clearing the cache of the ticker module, same results.
I have another layout with another ticker, no problem. When I input the other feed in that layout and set it to start from the begin of the feed, it starts at the end. Tried setting it to start at the end, but then the feed also starts at the end of the feed.
Try disabling the date sort in the Advanced settings on all three tickers.
That did the trick. Date sorting was enabled in one and disabled on the other two. Overlooked this option all this time!
