I’m trying to use a ticker to show 2 or 3 datasets one after the other with the marque up option. I was expecting it to scroll up showing the first dataset, then go on to the next ticker in the list and show that. Mine seems to repeat the first ticker.
If you have 3 tickers in one region and each ticker is set to display different dataset then it should work as you say - show first ticker then move to the next one and so on.
What duration did you set on your ticker? Is it also set with ‘duration is per item’ or not?
I will when I remake the layout as I have the ‘Volumes from docker-compose file no longer working after a reboot’ bug and lost all my layouts I’ve created
