Text Permissions
Is it possible to set up the permissions so that a user group can only edit the text in a panel?
I already tried it with the permissions set on only the textfield, on the panel where the text field sits in and the whole layout.
I always got the same result: the user could see the layout, see these panels but not the text inside them.
Thanks for your Help.
My verion is 2.1.0.
