Streamin Radio .pls
Hi, I need integrate a streaming radio? I have a link http://xxxxxxxxxxxxxxx.com/xxxx/radio.pls the client listen with VLC but I want integrate into template what I can to do?
Assuming you have VLC installed you could do that using an embedded media widget and the embed code for VLC streams (which I think you can get from the VLC website)
