Strange display in the schedule
I’ve just scheduled a campaign but when I look at it in the schedule, I can’t decipher the date and time. Can someone helps?
Thank you.
gl
PS: And also I would like to add that when I open an existing scheduled event, the ‘start time’ and ‘end time’ aren’t displayed. :confused:
Do you, by any chance, have ‘show international dates’ ticked in the settings on the regional tab?
Also what do you have there in date format please?
You are right: “show international dates” was checked. My date format are : Y-m-d H:i
gl
Ok, so without International dates it should show correct date (date format is also correct).
Now the date and time is correct when I open a scheduled event but the time is still appearing incorrectly in the calendar view.
And thank you! :slight_smile:
gl
Could you please tell me how incorrect is it?
ie. seems like a wrong timezone? Perhaps check if you have the correct timezone set in your CMS (also settings -> regional tab)
Here are my settings and the appearance of the time in the schedule. It should read 7:00 to 17:00
gl
hmm so…if you’d switch to day view, then it’s correct time there?
It is a bug, I kind of forgot about it, should be fixed in the next version.
Here is the day view:
gl
