I just created one timeline, basically it’s an Opening Soon sign. Is there a way to stop it from reloading or is the only way is to increase duration which really doesn’t fix the reloading? Is there a proper way to do this?
Thank you,
John
Thank you,
John
one way I found to solve the black blip is to add the same graphic as the background as well.
even In long playlists this works out nicely to add the first slide as the background. Smooths out the transition for me.
Thanks I’ll give that a try…
