We are looking to use “Stats” API to pull display down records. However we are only getting the layout, media & widget type records.
Is there any separate API to pull display down records?
I don’t think we have working API calls for availabilityData at this time, or rather, we don’t have it documented and I don’t think it will return anything that you can use at the moment - as it’s only there to create the charts in CMS not to return an object with data via API.
The route is /api/stats/data/availability
and while you can call it with correct parameters it will not return anything you can use for now.
