Hi All the stats archive is currently not running and when i manually run it, it don’t do anything
James
James
I don’t believe it is set to run by default.
If you want to enable it, you need to first configure it in the task settings, and then it will run per your schedule and the rules you’ve applied.
It won’t archive all stats, just those older than the periods you’ve told it to keep. If there’s no records in that window, then it won’t do anything. If there’s alot of records, then it will run batches up to the configured limit each time it is run in order to try and get back up to date.
A run on a large database can take serveral hours to complete.
