SQLSTATE[42S22]: Column not found: 1054 Unknown column 'display.deviceName' in 'field list'Skip this step
I’m getting this error trying to update the cms.
Step 11. SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘display.deviceName’ in 'field list’Skip this step
Thanks.
What versions are you trying to upgrade between please?
If you restore the database backup you too before upgrading, and try updating again, do you get the same error?
I just upgraded from 1.7.9 to 1.8.1
Initially I too faced same error. It worked after trying updating again. Thanks alex. :grinning:
