Sort order in Datasets
While I’m at it before summer vacation:
When trying to sort datasets by a certain column, you should type in some MySQL code, and I’ve tried “ORDER BY |col| ASC” and I’ve tried just the columns name ASC, but all it does is leave everything blank. Nothing shows. When I erase the code the dataset shows up again sorted as inputed.
Anyone that can point out my error? :wink:
For ascending order try to put only column name in Order field:
ex - Col1
for descending order you need to put DESC
ex - Col1 DESC
I hope it will help you :smile:
When trying to sort numbers xibo shows like this;
1,10,11,111,12,2,20,3
how can i sort like 1,2,3,10,11,12,20,111?
thanks
Hi Alper!
All data is stored as a string and the sort order is alphabetical, ie 40, 60, 80, 100 would result in this output: 100, 40, 60, 80 (because “1” comes before “4”).
Please try to prefix the narrower numbers with spaces so that they contain the same number of characters as the widest number. i.e. “40”,“60”,“80” become " 40", " 60", " 80". etc.for “2” you need to add 2xspace (assuming widest number is xxx)
Note: “100” being the widest, needs to remain “100”.
I hope that makes sense to you
02
03
Or if you need hundreds:
001
002
010
020
100
As an alternative until we get datatypes working correctly you could add a formula column like:
CONVERT(`otherColumn` AS UNSIGNED INTEGER)
And then sort by that column.
@dan i’ve tried your suggestion but it doesn’t works.
