SocketTimeoutException (okhttp3)
when using an Android Client, there are always error messages. The client is not able to download the files. The files are pending. It all worked already. Last week I upgraded to 1.8.3. Can anybody pls give me an advice?
Thank you
It would seem that player can’t reach the CMS correctly to download the resources, are you able to reach CMS address in the android browser on the device?
Are there any network settings that could interfere/block connection between the player and CMS?
Could you also tell us a little bit about your CMS installation is docker or not if not what’s the environment, web server etc?
Hello Peter,
it seems it was a network settings error. I set up a new dedicated server with docker and now it works all fine.
Thank you
