Shown xibo display on locked screen
my XIBO Installation works fine, but related to the company it-security guideline, I have the issue that the XIBO client should run, when the Windows client in a AD enviroment is locked. Is there a workaround for this topic?
Thank you in advance
You can configure Xibo to run as a screensaver - which can then run when the workstation is locked:
http://xibo.org.uk/manual/en/install_windows_client_screensaver.html
Hi Alex,
thanks for the Info.
I try it out and give some feedback
