Shell command execution
Hi again!
I’ve created a layout that would run .exe file. But the problem is that if I schedule it for example to start at 9:00 PM and end at 9:01 it would open 1 window every second. And if I “Schedule it now” and make it run for 1 sec it just won’t run at all.
Is there any way to make it open just 1 window?
Or is the source of my problem is my flawed shell command?
Thanks!
1111,
I would try to run a script that would check to see if the exe file is already running. If not, then execute the exe file.
Then call the script instead of the exe in Xibo.
Hm, that should work. Kind of stupid of me.
Thanks a lot!
No worries. Your welcome.
