Setting up a User
Hi I have had a user set up successfully for the past couple of months and everything was running smoothly until this morning. The user could only ever see only one layout that consisted of x3 rotating tariffs. They would then add a soup of the day every day and delete yesterdays one (leaving the tariffs alone). For some unknown reason when they uploaded todays soup of the day in came in twice. I tested it and it was definitely doing that. I deleted the layout and recreated a new one and it was doing the same. I then deleted the user and created a new one but still it’s doing it. I share the layout, share the images and yet when I log in as the user you can’t see the content within the layout or edit it. It is definitely there as when you click ‘preview layout’ it shows the content there. Even when I create a new user it still does this. I haven’t changed anything in the settings on the admin side. I have attached a screenshot so hopefully this will make sense.
I have tested the exact same thing with another account using the exact same settings and it works fine in that one.
Check the permissions on the region itself. I expect your user doesn’t have permission to view/edit the region.
