Selecting multiple rows for each menus
The ability to select multiple rows, and make actions on them, like deleting or removing them.
I’ve been doing tests with the API and the datasets, and after a few minutes, I end up with a lot dataset. The problem is, unlike layouts, you have to delete them one after the other.
I would really like so the same system as layouts, medias, displays, etc, added to datasets.
