Security for Xibo Player
Does Xibo store the files locally on the player? If an intel compute stick is used and given it can’t be secured easily, if someone takes the stick will it contain any of the info?
The Player downloads all the content you’ve scheduled for it locally so that it can play if the CMS is offline.
If physical theft is an issue for you, then you should use something like Bitlocker to encrypt the storage in your device.
thanks for the reply!
